Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Post processing: explode view of contour planes › Reply To: Post processing: explode view of contour planes
Omkar Kulkarni
The planes can be created only till the extent of the model. They can't be moved outside the boundaries of the model.
If size of the model is big I would suggest you to scale the model under the Domain tab and then setup the case.
I hope this helps.
Thanks,
Omkar Kulkarni
