Ansys Learning Forum › Forums › Discuss Simulation › Fluids › interface problem between 2 fluids in fluent › Reply To: interface problem between 2 fluids in fluent
Federico
Sharing topology between the 2 interfaces will combine both as a single interface.
You can try TUI command in boundary/slit-boundary-face to slit this interface into 2 faces in Fluent, and then create a mesh interface.
