Ansys Learning Forum Forums Discuss Simulation General Mechanical how to speed up autodyn? Reply To: how to speed up autodyn?
Missy Ji
Ahmed, the uncomputational time most likely is spent on I/O, you can go to Output, and pick Save, choose cycle frequency or time frequency.  Entera larger cycle or time, so less data points are written.
You may also Select Variables you want written to the Save file. Note that the selection of additional postprocessing variables will result in higher memory usage and file sizes. If a significant number are selected, some degradation in runtime performance can also be expected.Â
