Ansys Learning Forum › Forums › Discuss Simulation › Fluids › modeling heat transfer considering thin wall separating two fluids › Reply To: modeling heat transfer considering thin wall separating two fluids
October 6, 2023 at 3:44 pm
Please post a contour of temperature along the centre plane cutting the inlet/outlet pipes. You may need to create a separate isosurface of mesh for each fluid zone.
How does the heat flux balance look?
