Ansys Learning Forum Forums Discuss Simulation Fluids modeling heat transfer considering thin wall separating two fluids Reply To: modeling heat transfer considering thin wall separating two fluids
If you have a wall & shadow pair then you already have the wall. You can then give it a thickness (only need to do this once) and a material type unless Aluminium (default) is OK.
