Ansys Learning Forum › Forums › Discuss Simulation › Fluids › modeling heat transfer considering thin wall separating two fluids › Reply To: modeling heat transfer considering thin wall separating two fluids
September 26, 2023 at 4:28 pm
Wall & wall:shadow should be set as Coupled (default option) and you may want to give it a thickness. That means you have a conformal mesh and (should have) heat transfer.Â
