Ansys Learning Forum Forums Discuss Simulation General Mechanical Capacitance analysis of parallel plate capacitors in MAPDL Reply To: Capacitance analysis of parallel plate capacitors in MAPDL
ty_jpn
Hi Bill.
Thank you very much for reply.
The effect of the fringe electric field is simulated for each of the given capacitor dimension parameters, with the aim of deriving an approximate analytical expression. (e.g. the respective effects when looping the capacitor width in the do syntax from 0-200).
I understand about the annotations on theoretical values and fringe electric field estimation.
I want to output a list of the results when I loop through the results with the do syntax for this purpose.
Best regards, and thank you.
Takabayashi
