Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Connection of beam bodies › Reply To: Connection of beam bodies
Ankush Choudhary
Hi Javat, You need actual faces to create contact between them. These faces cannot be used for creating contacts. You can create contact on the lines; they will work fine.
