Ansys Learning Forum Forums Discuss Simulation Fluids Issues with Geometry Selections and Local Sizing in ANSYS Fluent Reply To: Issues with Geometry Selections and Local Sizing in ANSYS Fluent
Paul Stephen
Thank you for your prompt response and the information you’ve shared regarding edge-named selections in Fluent Meshing.
I’ve been exploring the Ansys Innovation Course you mentioned at “/courses/index.php/courses/add-local-sizing/lessons/how-to-use-edge-face-and-body-local-sizing-control-lesson-1/,” and it’s clear that edge sizing is indeed used in Fluent Meshing. In fact, I’ve successfully employed edge sizing for named selections in previous projects with Ansys and even with the same geometry and was able to mesh effectively in Fluent.
As the course explains the edge sizing option will only appear when a named selection for edges is assigned in SpaceClaim or Design Modeler. In my current case, I have assigned the named selection for edges, as indicated in my previous communication. However, Fluent does not seem to recognize this selection.
Given that this issue has emerged only in the past week, I’m beginning to wonder if it might be related to some settings change. If that’s the case, I would greatly appreciate any guidance on what changes could be responsible and how I can revert or modify them on my end.
Once again, thank you for your support, and I look forward to any insights or instructions you can provide to help resolve this matter.
Best Regards,
Paul
