Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Three plate joint using single bolt – how to connect using beam connection › Reply To: Three plate joint using single bolt – how to connect using beam connection
BALA
Thanks. Actually these plates are small part of one big assembly where frxed support is at different loacation so i cant keep bolt bolt hole as a fixed support, keeping bolt as solid may work but again i cant give any nonlinear contact so thats why i am not using it i just trying to figure out how can i connect these three plates using one beam connection because in actual case they are held by one bolt.
