Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Connection of beam bodies › Reply To: Connection of beam bodies
September 22, 2023 at 6:45 pm
Ankush Choudhary
Hi Javat,
If you have extracted them as beams, then these are not actual faces for which you can create a contact between them. If you want to create a contact between the two beams, then you have to select these two line bodies to create a contact.
