Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Three plate joint using single bolt – how to connect using beam connection › Reply To: Three plate joint using single bolt – how to connect using beam connection
ashish.khemka
Thanks for the update. At the bolt-hole location for the three plates, you can define a fixed support and then apply base excitation to the fixed support.
How to Perform Random Vibration Analysis | Ansys Courses
Ashish Kumar
