Ansys Learning Forum Forums Discuss Simulation General Mechanical Three plate joint using single bolt – how to connect using beam connection Reply To: Three plate joint using single bolt – how to connect using beam connection
BALA
Thanks for your reply, here that one bolt is holding all these three plate and applying Random vibration PSD profile so i cant use frictional contact.
