Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent Adjoint Solver;constant chordline constraint › Reply To: Fluent Adjoint Solver;constant chordline constraint
Aras karimi
Thank you for your answer.
1) Is it possible to constraint the movement of the wing in X and Z directions in other angles of attack or can this be done only in the angle of attack of zero degrees?
2) If I want to keep the camber line during optimization, how can I do this?
