Ansys Learning Forum Forums Installation and Licensing Ansys Products licensing issue- how to add file based licensing Reply To: licensing issue- how to add file based licensing
Rajeshwari Jadhav
Yeah I missed that part, then too can you open terminal and run following command:
1.            ping servername                  //instead of servername mention your server's name
type this command and send the screenshot of the output.
2.            telnet servername port_number
The default port number is 1055.
