Ansys Learning Forum Forums Discuss Simulation LS Dyna Negative Volume Reply To: Negative Volume
Jim Day
You might have a more stable simulation if you reduce the time step scale factor TSSFAC in *CONTROL_TIMESTEP. What solid element formulation are you using (ELFORM in *SECTION_SOLID) and what is the hourglass control type and hourglass coefficient?
