Ansys Learning Forum › Forums › Discuss Simulation › Fluids › [FLUENT] Ensuring Processor Affinity is Set › Reply To: [FLUENT] Ensuring Processor Affinity is Set
Aras karimi
Hello
I also have your exact operating system, however, when I compare it with a system with CPU i7 4770K (4 cores), its speed is not very high and there is a slight difference.
Do you also have this problem?
Do I have to do anything special?
When I open Fluent, I get this message in the Fluent console. Do you also receive this message?
Note: Rank = 0: Process affinity not being set (6).
Note: Rank = 1: Process affinity not being set (6).
Note: Rank = 2: Process affinity not being set (6).
Note: Rank = 3: Process affinity not being set (6).
Note: Rank = 4: Process affinity not being set (6).
Note: Rank = 5: Process affinity not being set (6).
Note: Rank = 6: Process affinity not being set (6).
Note: Rank = 7: Process affinity not being set (6).
Note: Rank = 8: Process affinity not being set (6).
Note: Rank = 9: Process affinity not being set (6).
Note: Rank = 10: Process affinity not being set (6).
Note: Rank = 11: Process affinity not being set (6).
Note: Rank = 12: Process affinity not being set (6).
Note: Rank = 13: Process affinity not being set (6).
Note: Rank = 14: Process affinity not being set (6).
Note: Rank = 15: Process affinity not being set (6).
