Ansys Learning Forum Forums Discuss Simulation Electronics HFSS field display problem Reply To: HFSS field display problem
Aymen Mzoughi
Make sure you are plotting the field for the solution frequency, or use a discrete sweep and save the fields for the frequency points you would like to investigate.
For more information about S-Parameters in HFSS, please refer to the help documentation under ansyshelp.ansys.com
