Ansys Learning Forum Forums Discuss Simulation Fluids simulation results do not match journal references Reply To: simulation results do not match journal references
Alwan Hibatullah
I took identical data from the analyzes using inlet, wall, and outlet temperatures. which I then compared with the correlation equation
if I take Nusselt number data from fluent, the value is very high, which is above 100
