Ansys Learning Forum Forums Discuss Simulation Electronics Constrained Optimisation HFSS Reply To: Constrained Optimisation HFSS
Mrinmoy Bharadwaj
There is no provision of integrating solvers in optimetrics. If you are planning to make a new workflow of optimization/DOE using other tools in the workflow, you would need to use Optislang as it is the only tool that is capable of Process Integration and Design Optimization. You can set-up your integrated workflow in Ansys Optislang with the desired set of Objectives and constraints. You may log in into the Ansys Learning Hub for learning more on Optislang.
