Ansys Learning Forum Forums Installation and Licensing Ansys Products Workbench loads without opening Reply To: Workbench loads without opening
Rajeshwari Jadhav
Hi AMR,
Can you please check if any antivirus software is blocking the Ansys application?
  • Go to START > Event Viewer > Expand the Windows Logs and choose Application. In application log check if any Error is shown when you launch the workbench.
Can you check while installation any error had occured?
  • Goto the install.err, install_licconfig.err, install.log, install_licconfig.log logs. (C:\Program Files\ANSYS Inc)
Can you goto start menu and type %appdata%, rename the Ansys folder over there as Ansys.old and relaunch the application.
