Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › displacement in 2 ends simultaneously › Reply To: displacement in 2 ends simultaneously
August 5, 2023 at 2:44 pm
peteroznewman
Bilinear Kinematic Hardeneing with a zero Tangent Modulus is the simplest plasticity model to use. One benefit is that in many models, it provides a conservative result. That means the load when failure is predicted is lower than the actual load when failure occurs because the real material has a non-zero tangent modulus so the structure can carry more load at failure than what is predicted with a zero Tangent Modulus.
There are many plasticity models. Take the free training courses to learn more.
