Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › displacement in 2 ends simultaneously › Reply To: displacement in 2 ends simultaneously
August 5, 2023 at 8:57 am
Arash Kavosi
thank you so much
I should keep the changes you mentioned for "Bilinear Kinematic Hardening"? is it suitable for every material I intend to apply? for example when I want to use Co-Cr material I should to same for it? is it allowed and the extracted data is reliable?Â
