Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Reverse flow problem › Reply To: Reverse flow problem
SRP
For a case of single flow (means you are not considering condensation and want to see only the species tranport with flow), I suggest you to turn off the species transport equation and run simulation for 800 iteration so that we get to know that there was no issue with the continiuity and momentum equation. Later on you can turn on the species tranport.
Thank you.
