Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Reverse flow problem › Reply To: Reverse flow problem
July 31, 2023 at 6:26 am
Hi. Thanks for the help.
1. The direction of gravity is correct.
2. I checked 2000 iterations but the continuity equation does not converge at this value of the inlet velocity
3. I want to model a two-phase flow of moist air so that I can observe the condensation processes.
However, with “transport species” the problem that occurs is the same
