Ansys Learning Forum Forums Discuss Simulation General Mechanical “An error occurred inside the SOLVER module: general error” when resolving model Reply To: “An error occurred inside the SOLVER module: general error” when resolving model
Nanda
Hello Alex,
Can you try following suggestions made in this forum discussion and let us know if that didn't help:
Ansys Mechanical – “An error occurred while starting the solver module”
Probably resetting app data might help sometimes. Here's how you can do it:
  1. Go to the Start Menu and open %temp% folder. Search for ‘.ansys’ folder and rename it to ‘.ansys.old’ then launch the application.
  2. Open a file explorer and type %appdata% in the address bar.
Locate the Ansys folder --> select version (V231) and rename it to V231.old
Nanda.
