Ansys Learning Forum Forums Discuss Simulation 3D Design Share Topology Coincidence Tolerance Reply To: Share Topology Coincidence Tolerance
Nanda
Hello Petri,
When share is activated, you can set the tolerance value using “coincidence tolerance” option. Potential candidates outside the coincidence tolerance are ignored.
For more information on using share tool, refer to this link:
Share Tool (ansys.com)
It is recommended to start a new post rather than following up in old threads for two reasons:
  1. You will get notified if you're owner of the post, when someone replies to you post.
  2. Generally unanswered posts grab more attention than which already have prior comments.
Nanda.
