Ansys Learning Forum Forums Discuss Simulation LS Dyna Part Damping cause negative volume error Reply To: Part Damping cause negative volume error
Tonmoy
Hi Ben_Ben,
To find an element by its ID in LS-PrePost, follow these steps:
  • Go to FEM>Element Tools>Find on the top menu.
  • Click the Element radio button and enter the ID in the bottom section of the Find pane. LS-PrePost will select the element for you.
  • To see only the selected element, click the ‘show only’ radio button in the middle of the pane.
I hope this helps you visualize the element you are looking for.
