Ansys Learning Forum Forums Discuss Simulation General Mechanical Importing loads from external data archive Reply To: Importing loads from external data archive
Miguel Socias
Dear Akshay,
Thank you very much for your response.
When working with pressure values (always normal to the surface where the pressure is applied), the steps to follow are well described in the document attached to the link. However, I am interested in working with forces (not always normal to the surface). Forces are vectorial magnitudes, therefore, force vectorial components (x, y, z) need to be specify. How can that be done?
Thanks in advanced.
