Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Change courant flow number in TUI › Reply To: Change courant flow number in TUI
July 10, 2023 at 8:52 am
Assuming you are using Pressure based solver, please check if the Pseudo time method is ON or OFF. And in the Controls, check if the option to change the Courant number is available. If it is, then you need to use: solve/set/p-v-controls. Here, Fluent will give you an option to change the Control parameters and one of them would be Courant number.
