Ansys Learning Forum Forums Discuss Simulation Fluids Heat expression Reply To: Heat expression
Agung Limowa
hi I have tried to calculate and create an expression but it has 2 different dimensions so I want to make the temperature increase as the position decline, so it has [m] dimension and [C] dimension. i have tried to split the expression but it didn't seem to work, what i should do
