Ansys Learning Forum Forums Discuss Simulation General Mechanical Rotational velocity in static structural Reply To: Rotational velocity in static structural
Samuele Luigetti
Yes the deformation. I mean, if i think at something rotating at certain rotational velocity, the type of analysis in my mind is dynamic, not static. So my question is if for example i have a simple disc on a fixed shaft and the disc is rotating at tot rpm, the diplacement available on the solution is the one due to centrifugal force?
