Ansys Learning Forum Forums Discuss Simulation Fluids Help with post processing Reply To: Help with post processing
Dubey92
No. When I plot the temperature contours in the iso-surface, it does not fill the lower section. I think the second image is also from CFD-Post. Also, can you tell how the particles are more defined and filled in the second image. I have also used volume rendering in my case but they don't look that good.
