Ansys Learning Forum › Forums › Discuss Simulation › Materials › Solution not converging ( Fibre Push Out ) › Reply To: Solution not converging ( Fibre Push Out )
mrife
Hi Akshit
I mean literally a two element test.  CAD model 2 cubes with 2 touching faces.  Mesh each with one element.  Define the CAM bonded contact between them.  Apply BC and load, then post-process to determine whether they pull apart per the CZM material definition or not.
