Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Negative K Value in xxx cells › Reply To: Negative K Value in xxx cells
Check the mesh quality: note that's cell metrics (in Meshing) and resolution (Meshing or the Fluent solver). You'll need to look at and then judge the latter.
