Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent adjoint solver; constant camber line constraint › Reply To: Fluent adjoint solver; constant camber line constraint
			June 16, 2023 at 6:32 pm
	The goal is to optimize the shape of the wing, which ultimately leads to increased lift or reduced drag. The final optimized wing has improved increased lift and reduced drag, but the wing sections have gonacon airfoils and are different from the original wing geometry airfoils.
My goal is for the optimized wing to have the same airfoils as the original wing at different cross sections.
 You are navigating away from the AIS Discovery experience
