Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › The problem with the material in ACP › Reply To: The problem with the material in ACP
June 14, 2023 at 6:21 pm
Thanks for the answer. Yes, I figured out the play type. And I have the following error regarding the destruction criteria, as you said
But how do I find these parameters for a new composite? I made it in the material designer and now it should have new destruction parameters. The material designer can determine them for me on the new resulting composite?
