Ansys Learning Forum Forums Discuss Simulation Fluids Difference in HPC results and PC results. Reply To: Difference in HPC results and PC results.
Ramesh Chandra Mishra
Hi Rob.
I got the correct results. The problem was with the inlet boundary conditions . Like you said, velocity magnitude zero will give the zero results. I corrected it.
Thanks.
