Ansys Learning Forum Forums Discuss Simulation Fluids Inlet and outlet Temperatures Reply To: Inlet and outlet Temperatures
Vicent Marwa
Am using Ansys to predict time taken to cool a container with three layers, Outer layer Galvanized sheet of 1.5m, between layer polyurethane foam of 60mm and inner layer aluminum of 1mm. The container is surrounded by evaporator using compression vapour system.
How to predict time of cooling? if the surrounding is 32 degree and inner is 2degree
