Ansys Learning Forum Forums Discuss Simulation General Mechanical /post1 trouble wtith Ansys Workbench thermal transient Reply To: /post1 trouble wtith Ansys Workbench thermal transient
John Miller
Hello Chandra,
thank you for your helpfull answer.
When I apply the changes the plot isn’t still what I indended.
Here is my applied script:
/graphics,power
/post1
step_nr=5
set,step_nr
*stat
esel,s,type,,mycid !
! set colors for white background
/RGB, INDEX,100,100,100, 0
/RGB, INDEX,80,80,80, 13
/RGB, INDEX,60,60,60, 14
/RGB, INDEX,0,0,0, 0
/show,png
/trlcy,cm,0,bed
/trlcy,cm,0,bed2
/trlcy,cm,1,path
esel,s,ename,173
/trlcy,elem,0
esel,all
/view,all,1,1,1
/angle,1,0,ZM,0
/angle,2,0,ZM,0
/eshape,1
ples,cont,flux          ! plot heat flux through contact elements
etable,tcc_i,nmisc,94
plet,tcc_i,1
allsel
! plot 1 = thermal flux at the contact surface
! plot 2 = applied thermal contact conductance
The plots are looking this way:
The solve out file shows this:
         ***** ANSYS RESULTS INTERPRETATION (POST1) *****
 *** NOTE ***                            CP =     413.531   TIME= 13:48:38
 Reading results into the database (SET command) will update the current
 displacement and force boundary conditions in the database with the
 values from the results file for that load set.  Note that any
 subsequent solutions will use these values unless action is taken to
 either SAVE the current values or not overwrite them (/EXIT,NOSAVE).
 PARAMETER ARG1 =     5.000000000
 Use PowerGraphics for solid and shell elements
 Facet level set to 1 for maximum speed
  Use /EFACET,2 for curved boundaries.
 You have already entered the general postprocessor (POST1).
 PARAMETER STEP_NR =     5.000000000
 USE LOAD STEP     5  SUBSTEP  LAST    FOR LOAD CASE 0
 SET COMMAND GOT LOAD STEP=     5  SUBSTEP=     1  CUMULATIVE ITERATION=     5
   TIME/FREQUENCY= 0.25000
 TITLE= RADuCONV--Thermisch-transient (A5)
 ABBREVIATION STATUS-
  ABBREV    STRING
  SAVE_DB   SAVE
  RESUM_DB  RESUME
  QUIT      Fnc_/EXIT
  POWRGRPH  Fnc_/GRAPHICS
 PARAMETER STATUS-           (     84 PARAMETERS DEFINED)
                  (INCLUDING       24 INTERNAL PARAMETERS)
 NAME                              VALUE                        TYPE  DIMENSIONS
 ABC                              -1.00000000                  SCALAR
 AX                               5.000000000E-004             SCALAR
 BX                                0.00000000                  SCALAR
 CID                               7.00000000                  SCALAR
 DT                               5.000000000E-002             SCALAR
 DTCOOL                           0.100000000                  SCALAR
 DY                               5.000000000E-004             SCALAR
 DZ                               5.000000000E-004             SCALAR
 HC_A                              100.000000                  SCALAR
 HC_B                              80.0000000                  SCALAR
 HC_C                              60.0000000                  SCALAR
 HC_EX_COOL                        30.0000000                  SCALAR
 HC_OUT                            30.0000000                  SCALAR
 I                                 20.0000000                  SCALAR
 ICOOL                             1.00000000                  SCALAR
 II                                1.00000000                  SCALAR
 IIJJ                              2.00000000                  SCALAR
 IJK                               2.00000000                  SCALAR
 J                                 1.00000000                  SCALAR
 JJJ                               1.00000000                  SCALAR
 KK                                20.0000000                  SCALAR
 LC                                1.00000000                  SCALAR
 PC                                1.00000000                  SCALAR
 PDY                              1.000000000E-003             SCALAR
 SC                                1.00000000                  SCALAR
 STEP_NR                           5.00000000                  SCALAR
 T                                 1.00000000                  SCALAR
 TA                                80.0000000                  SCALAR
 TB                                60.0000000                  SCALAR
 TBED                              40.0000000                  SCALAR
 TBULK                             25.0000000                  SCALAR
 TC                                50.0000000                  SCALAR
 TCC2                                              TABLE       2       1       1
 TEMPERATURE                     TEMP                            CHARACTER
 TEX_COOL                          40.0000000                  SCALAR
 THXY1                             0.00000000                  SCALAR
 THXY2                             0.00000000                  SCALAR
 THYZ1                             0.00000000                  SCALAR
 THYZ2                             0.00000000                  SCALAR
 THZX1                             0.00000000                  SCALAR
 THZX2                             0.00000000                  SCALAR
 TID                               8.00000000                  SCALAR
 TL                                70.0000000                  SCALAR
 TOL                              1.000000000E-006             SCALAR
 TOUT                              10.0000000                  SCALAR
 TR                               0.100000000                  SCALAR
 VX                               1.000000000E-002             SCALAR
 XLOAD                            5.000000000E-004             SCALAR
 XR1                              1.000000000E-002             SCALAR
 XR2                              8.000000000E-003             SCALAR
 X_BOX_B                          5.000000000E-004             SCALAR
 X_BOX_C                          5.000000000E-004             SCALAR
 YCORR                            1.000000000E-003             SCALAR
 YLOAD                            5.000000000E-004             SCALAR
 YR1                              1.500000000E-003             SCALAR
 YR2                              1.500000000E-003             SCALAR
 Y_BOX_B                          5.000000000E-004             SCALAR
 Y_BOX_C                          5.000000000E-004             SCALAR
 ZR1                              5.000000000E-004             SCALAR
 ZR2                              5.000000000E-004             SCALAR
 PARAMETER PRIMARY VARIABLE LISTING-
 NAME                                           VARIABLE(S)
 TCC2                                           1=TEMP 2=     3=
 *** WARNING ***                         CP =     413.969   TIME= 13:48:39
 Specified range of 0 to 0 is not permitted.  The ESEL command is
 ignored.
 RED=100% GREEN=100% BLUE=100%
  for color index  0.
 RED=80% GREEN=80% BLUE=80%
  for color index 13.
 RED=60% GREEN=60% BLUE=60%
  for color index 14.
 RED=0% GREEN=0% BLUE=0%
  for color index  0.
 /SHOW SWITCH PLOTS TO  PNG         - RASTER MODE.
 COMPONENT BED      TRANSLUCENCY SET TO   0.0000
 COMPONENT BED2     TRANSLUCENCY SET TO   0.0000
 COMPONENT PATH     TRANSLUCENCY SET TO   1.0000
 *** WARNING ***                         CP =     414.016   TIME= 13:48:39
 For item = ENAME, component = 173 is invalid.  The ESEL command is
 ignored.
 ALL ELEM TRANSLUCENCY SET TO   0.0000
 ALL SELECT   FOR ITEM=ELEM COMPONENT=
  IN RANGE         1 TO      99718 STEP          1
      84182  ELEMENTS (OF      84182  DEFINED) SELECTED BY  ESEL  COMMAND.
 view point for window  1    1.0000      1.0000      1.0000
 ROTATION ANGLE FOR WINDOW 1 IS     0.00 ABOUT AXIS ZM
 ROTATION ANGLE FOR WINDOW 2 IS     0.00 ABOUT AXIS ZM
 ELEMENT DISPLAYS USING REAL CONSTANT OR SECTION DATA WITH FACTOR     1.00
 DISPLAY ELEMENT SOLUTION,  ITEM=CONT  COMP=FLUX
 CUMULATIVE DISPLAY NUMBER   1 WRITTEN TO FILE file000.png       - RASTER MODE.
 DISPLAY TITLE=
 STORE TCC_I    FROM ITEM=NMIS COMP=  94  FOR ALL SELECTED ELEMENTS
 *** WARNING ***                         CP =     415.156   TIME= 13:48:39
 The ETABLE command has requested item = NMISC, comp = 94 of element 1
 (element type SOLID279).  0.0 is output, as this item does not exist.
 Checking for this discontinues.
 DISPLAY ELEMENT TABLE,  ITEM=TCC_I     OPER=1
 *** NOTE ***
  libpng version 1.0.8 - July 24, 2000
    Copyright (c) 1998-2000 Glenn Randers-Pehrson
    Copyright (c) 1996, 1997 Andreas Dilger
    Copyright (c) 1995, 1996 Guy Eric Schalnat, Group 42, Inc.
 ZLIB Version 1.2.11 Copyright (C) 1995-1998 Jean-loup Gailly and Mark Adler
 CUMULATIVE DISPLAY NUMBER   2 WRITTEN TO FILE file001.png       - RASTER MODE.
 DISPLAY TITLE=
 SELECT ALL ENTITIES OF TYPE= ALL  AND BELOW
 PARAMETER LOADSTEP =     1.000000000
 USE LOAD STEP     1  SUBSTEP  LAST    FOR LOAD CASE 0
 SET COMMAND GOT LOAD STEP=     1  SUBSTEP=     1  CUMULATIVE ITERATION=     1
   TIME/FREQUENCY= 0.50000E-01
 *GET  NUMNODE   FROM  NODE  ITEM=COUN       VALUE=  283054.000
 SET PARAMETER DIMENSIONS ON  NODETEMP
  TYPE=ARRA  DIMENSIONS=   283054        4        1
 VECTOR GET OPERATION  nodetemp(1,1)  VECTOR LENGTH=  283054
 NAME= NODE         1  LOC   X
 VECTOR GET OPERATION  nodetemp(1,2)  VECTOR LENGTH=  283054
 NAME= NODE         1  LOC   Y
 VECTOR GET OPERATION  nodetemp(1,3)  VECTOR LENGTH=  283054
 NAME= NODE         1  LOC   Z
 VECTOR GET OPERATION  NodeTemp(1,4)  VECTOR LENGTH=  283054
 NAME= NODE         1  TEMP
 OPENED FILE= myTempfileWF.txt FOR COMMAND FILE DATA
 MAXIMUM TERM IN RESULT VECTOR=       1
 STRIDE IN VECTOR OPERATION=     1
  COMMAND FILE CLOSED
 PARAMETER NODEID =     27844.00000
 EXIT THE ANSYS POST1 DATABASE PROCESSOR
I’m only interested in the display of the contact 173 elements and the heat flux through these elements. But I can’t plot it this way. The grey part named “path” should be transparent but it’s not. The underlying “bed” and “bed2″ should be not transparent, this is right in the second plot.
With best regards
John M.
