Ansys Learning Forum Forums Discuss Simulation General Mechanical Structural Analysis Issues on A Cable-Stayed Bridge Reply To: Structural Analysis Issues on A Cable-Stayed Bridge
peteroznewman
The contacts are Far Open because the Pinball Radius is smaller than the distance between the nodes.
Instead of using contacts to bond elements together, try using Node Merge which will move the nodes to be coincident, then delete one of the nodes after it modified the element to use the other node.
