Ansys Learning Forum Forums Discuss Simulation Fluids Velocity Profile changes its mass flow rate from outlet to .prof Reply To: Velocity Profile changes its mass flow rate from outlet to .prof
If you're using the open channel the downstream flow will alter the inlet mass flow. How does the free surface look? Is there a hydraulic jump?  I know why profiles are used, but it's sometimes better to just accept the compute overhead and model the whole lot in one go.
