Ansys Learning Forum Forums Discuss Simulation General Mechanical Assign custom profile in Spaceclaim to do beam analysis Reply To: Assign custom profile in Spaceclaim to do beam analysis
peteroznewman
When you have the full length solid, create two planes where you want the supports and use Split Body to make 3 pieces. Extract each piece into a Beam.  Then on the Workbench tab, use the Share button to make sure that the pieces share a nodes at each cut plane. Then in Mechanical, you will have a Vertex to support.
