Ansys Learning Forum Forums Discuss Simulation General Mechanical Spur gear stress analysis Reply To: Spur gear stress analysis
Florian.CHANCEL
Ok, you have to set up some steps to help the static calculation
Step 1 : You lock (0°) the rotation of the left pinion, and apply the torque on the right pinion.
Step 2 : you rotate the left pinion (for example 10°) => In this step, you have to set up sub step every 1°(or more) => Substeps are the key to the convergence. Your calculation have to stay in static, if the rotation gap is to big, calculation will fail
Advice 1 : You should fixe your remote point on the two cut edges of your pinion and set up the rigid behavior
Advice 2 : turn on "large displacement"
Advice 3 : Weak springs are not a problem, you just have to check if the reaction forces are near 0 N after your calculation.
Advice 4 : 360° is not useful, I think juste a rotation on 3 teeth are good enough to capture all results.
Can you show your mesh, can you send me CAD file in .step ?
Can you show me the parameters of your frictionnal contact ?
