Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Transmission of vibration between structures › Reply To: Transmission of vibration between structures
September 19, 2022 at 7:04 pm
>>How does the frame base connect to the ground? Â Are there four mount points that are fixed to ground?Â
Yes, the base is firmly fixed to the ground
>>A Modal analysis will show the free vibrations of that structure. You should add a Distributed Mass on the pipe elements to represent the weight of the liquid in the pipe.
Just to check free vibrations? And all?
If there are free vibrations, then there is vibration; if there are no free vibrations, then there is no vibration. Right?
