Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Is it possible to update only one output parameter column in the parameter set? › Reply To: Is it possible to update only one output parameter column in the parameter set?
Pooja S
"Assuming the case & data still exist you could manually extract the value(s). "
Could you tell me how to do this? The second last column and the one before are moments about x and y axes, and the third was supposed to z where I mistakenly put x again.
Also even with a reasonably (to be honest unreasonably coarse) coarse mesh and 16 processes, the analysis seems to be quite slow : is there any way to speed it up ?
