Ansys Learning Forum Forums Installation and Licensing Ansys Products Installation completed with errors Reply To: Installation completed with errors
Alessia Pintossi
That's the text from the .err file:
Ansys installation: gio set 15 13:35:11 2022
Revision: 2022 R2
   ###### Error #######
   Error executing configuration script 'C:\Users\pinto\AppData\Local\Temp\ans_install_tmp18784\config\AnsConfigWB.tcl'
   '"C:\Users\pinto\AppData\Local\Temp\ans_install_tmp18784\tcl\bin\winx64\tclsh.exe" "C:\Users\pinto\AppData\Local\Temp\ans_install_tmp18784\config\AnsConfigWB.tcl"  -installdir "C:\Program Files\ANSYS Inc\ANSYS Student" -rev 222 -dotrev 2022 R2 -scripttosource "C:\Users\pinto\AppData\Local\Temp\ans_install_tmp18784\config\ConfigCommon.tcl" -sourcedir "C:\Users\pinto\AppData\Local\Temp\ans_install_tmp18784" -os_lang en-us -install ' terminated after 1 attempts with the following error(s):
       Unknown error
   Exit Code: 1
   Graphics Driver Verification and Setup Error.
So you say I'll be able to use the program anyways?
