Ansys Learning Forum › Forums › Discuss Simulation › Photonics › About point and range scans › Reply To: About point and range scans
Guilin Sun
You are sweeping single wavelength but the start and stop wavelengths are not the same, which is wrong!
In most cases you do not need to sweep the wavelength. Instead, you need to use Boradband for mode source here:
You can read out the wavelength and see if they are the same. I am sure if you set correctly the result will be the same.
