Ansys Learning Forum Forums Discuss Simulation Photonics About point and range scans Reply To: About point and range scans
Guilin Sun
One thing I forgot to mention: when you sweep wavelength, please sweep both the “wavelength start” and the “wavelength stop” in order to have a single wavelength result.
I did a simple test and ensured that both methods give exacly the same result, provided that you have set up the wavelength stop the same as the wavelength start.
