Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Remove Parameter Set from Workbench › Reply To: Remove Parameter Set from Workbench
April 4, 2022 at 12:19 pm
The parameter set appears when we define a parameter by checking a box besides the respective property. A complete loop indicates there are both input and output parameters defined for the analysis system. It can be removed by simply unchecking the box next to the respective property and refreshing the project.
Hope that helps.
Thanks Sahil
